Apr 22, 2024 11:58 PM UTC
Oracle Database import question
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS27
Can we import database using the following command: (This command has exclude=statistics)
impdp system/manager@wind directory=export dumpfile=EXPDP_acumedprd_19032023_01.dmp,EXPDP_acumedprd_19032023_02.dmp,EXPDP_acumedprd_19032023_03.dmp,EXPDP_acumedprd_19032023_04.dmp exclude=statistics LOGFILE=import_acumedprd.log schemas=acumedprd
And then run the following command as per article https://www.ptc.com/en/support/article/CS129969 to gather statistics manually:
execute dbms_stats.gather_schema_stats('DBUSER', DBMS_STATS.AUTO_SAMPLE_SIZE , CASCADE =>TRUE);
    BenLoosliAnswer
    Apr 23, 2024 1:22 PM UTC
    Here is what I do:
    a. Export the current database with the expdp command and Windchill shutdown
    expdp System/@wind schemas=PDM directory=expdp_full dumpfile=full_exp.dmp exclude=statistics logfile=full_expdp.log
    b. Import the Oracle backup into the PDM user space
    Impdp System/<password>@wind  schemas=PDM directory=expdp_full dumpfile=full_exp.dmp logfile=full_imp.txt
    c. Gather DB Statistics
    SQLplus PDM/<password>@wind
    Execute dbms_stats.gather_schema_stats(‘PDM’,DBMS_STATS.AUTO_SAMPLE_SIZE, CASCADE =>TRUE
    I do not see any reason your method should not work since in both cases the statistics are not part of the imported DB.
    BenLoosli23-Emerald IIIAnswer
    Here is what I do:
    Jun 6, 2024 2:00 PM UTC
    Are you still dropping WCUSER before importing the new dumpfile?
    Jun 6, 2024 2:28 PM UTC
    Yes
     Between step a and b, I do the following:
    Drop user <pdm_username>
    @create_user.sql - this will ask for 3 pieces of infomeation
    PDM username
    Temp Tablespace name - TEMP
    Userdata Tablesapce name - USERS
