May 23, 2025 11:41 AM UTC
Oracle DB Dump import for WC10
I am using Windchill PDMLink Release 10.2 and Datecode with CPS M030-CPS27
preparing to upgrade from the WC10 version to the WC13 version, Although there were 1743 errors in the log file during the Oracle DB import, there were no error tables written there.
Could you please clarify whether we can disregard this alert?
Here are the errors that I faced
Last line in the Log file:
Job "SYSTEM"."SYS_IMPORT_FULL_01" completed with 1743 error(s) at Fri May 23 13:07:47 2025 elapsed 0 00:04:44
May 26, 2025 8:39 AM UTC
Based on the error like below, it appears that the Database schema has been on the target database, in fact, it should not be there before the import. Please make sure that the database schema are not been created before importing the dump. You just need to create the database schema user only.
ORA-39151: Table "WTDBUSER"."PARAMETERATTRIBUTEDEFNLINK" exists. All dependent metadata and data will be skipped due to table_exists_action of skip
ORA-39151: Table "WTDBUSER"."VARIANTSQUEUEENTRYINFO" exists. All dependent metadata and data will be skipped due to table_exists_action of skip
ORA-39151: Table "WTDBUSER"."GENERICVARIANTLINK" exists. All dependent metadata and data will be skipped due to table_exists_action of skip
ORA-39151: Table "WTDBUSER"."WPBASELINESEED" exists. All dependent metadata and data will be skipped due to table_exists_action of skip
Community Moderator
May 28, 2025 4:46 PM UTC
Hi @GOKUL1,
Anurag
May 28, 2025 5:33 PM UTC
What versions of Oracle are you using with Windchill 10 and Windchill 13?
I do not think you can do an upgrade from WC 10 to WC 13 directly. You may need to do an intermediate WC version or two.
