7-Bedrock
Sep 28, 2026 10:04 AM UTC
Part Configuration and Instance - Instance allocation in a multi-level structure
Hello, I need additional information to those available in the Help Center documentation for Part Configuration and Instance.
Windchill 12.0.2.8
When allocating child Instance in a Parent Instance Structure, it is OK to have Untraced sublevel BOM containing child with Trace Code Serial Number or Lot which will be allocated from this Parent Instance ?
It seems that this is possible but it is recommended ?
In our case, these untraced level in the Manufacturing BOM Structure are like Gathering Part, it correspondent to intermediate advancement of the assembly, not item in stock.
For me it is OK until these untraced sub-levels have a quantity of one, if up to one, there is a problem to link child occurrence with Reference Designator (Position in the product).
What is your point of view ?
Catalina
Community Manager
Oct 2, 2026 4:14 PM UTC
Hi ​@TM_14515368
Thank you for your question. 
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Catalina | PTC Community Manager
