Mar 17, 2026 10:51 AM UTC
Part Instance Allocation - Prevent Allocation into Multiple Parent Instances
Version: Windchill 13.0
Use Case: I have noticed it is possible to allocate the same part instance object into multiple different parent part instances.
Description:
In reality, this would never happen. It should only be possible for a part instance to be allocated into one parent part instance. Does anybody know if it is possible to prevent Windchill from assigning a single part instance into multiple different parent part instances?
Fadel
23-Emerald II
Mar 18, 2026 1:36 PM UTC
You can create a uniqueness constraint on db level for child instance id
Buiꓘa
