Apr 29, 2020 9:44 AM UTC
Part Numbering in Windchill
while creating part number in windchill(Auto Numbering),how to add custom prefix with number.
Example:
Part Name is :HEXBOLT.
Part Number Should be HB00001
Part Name is CUSHIONBOLT
Part Number should be CB00002
How to do this .
Can anyone help me.
Mohammed Sadiq J
Apr 29, 2020 1:34 PM UTC
You will need multiple OIRs for each type that you want a unigue prefix for.
You might be better off creating those types of parts in a family table.
jms7865-Regular MemberAuthor
Apr 30, 2020 3:33 AM UTC
Thank you Ben Loosli for your reply.
You will need multiple OIRs for each type that you want a unique prefix for.
say for instance if I have 1000 parts then I need to have 1000 OIRs with unique prefix.
That is huge and not the right one since part numbers are keep on increasing day by day.
can you pls elaborate a bit family table
Thanks and Regards
Mohammed Sadiq J
Apr 30, 2020 2:37 PM UTC
No, you only need an OIR for each prefix you need.
You may have 128 HB parts, that is 1 OIR.
For your 234 CB parts, that is a second OIR.
Family tables allow you to have multiple instances of a common design in a single file. All of the descriptions and interfaces are the same for all instances. Makes replacement very easy. Here is a sample family table of hex head cap screws.
