7-Bedrock
Part State/Version management for Wire use in flexible assembly
In a CAD-centric configuration (Windchill 12.0.2.8+SolidWorks), to handle “wire” and similar component with multiple representation, we use the Flexible Assembly method and its fine...until we need to Released this Part in order to Released a Product (EBOM) while other CAD Team also use this Part to work on the design of other products (EBOM)…
As soon as we need to do a Change notice, I fear that the problems will start :
  • Who across the different CAD Team is responsible of this Change notice is not clear.
  • The Change notice will be open during a longue periode.
  • Change request coming for released product or on the document of this Part will leads to the need to modify and Released this Part while other new CAD linked to this Part for new product are still not approved.
How to manage properly the lifecycle and change management of the “Wire” Part (EBOM) using the Flexible Assembly method?
(We have MBOM with no CAD, visualization for MBOM is based on the BOM structure and the occurrence link to the EBOM)
For example:
  • Customization to be able to add or remove on a Released Part new (or just new non-approved) CAD with image association without versioning the Part or change the State.
    Change during the assembly after a CAD is approved will result, in the history of the Wire Part, of a mix of change coming from definition of the wire and its integration in their multiple Parents. Existing CAD maybe deleted by mistake.
    => Quality and PLM Administrator will not like.
  • Leave the Flexible Assembly method, instead, each “path” (Occurrence) of the wire have a distinct CAD assembly owner of a gathering Part, containing :
    - The same child CAD linked in owner to the Part of the “Straight” Wire but without volume.
    - An another child CAD, representing the wire folded to the “path” of this occurrence, with a image link to the Gathering Part of the assembly.
    Change on the Wire and change of the Path of the Wire in the assembly are dissociated.
    => Designer will not like (Big assembly), but manufacturing will enjoy to not have to repair occurrence link resulting of multiple split of usage link!
Can we have a CAD contributing to the structure of his Parent Part sharing a visualization for his owner Part but not sharing a volume in the visualization of the Parent Part structure in Windchill ?
Thanks !
Not sure if this will help, but have a look here.
https://www.ptc.com/en/support/article/CS370130
7-Bedrock
Thanks Bryan,
I think what i need is :
Integration with Other Applications > Managing CAD and Part Relationships in Windchill > Building CAD and Product Structure > When to Build
Automatic Builds
Image-associated CAD Documents and Model Items can be configured to not build or iterate their related parts. This is done with the server-side preference Build Image Association by Default. When this preference is set to No, the child part of the CAD Document is not updated. This is often used when the CAD object is related to a purchased or standard component that is already released and cannot be modified.
This sentence is not in the version 12.0.2 manual, Can anyone confirm for me that we have to wait for the version 13.0.2?
Has anyone tried this option, I would like to know if there are any side effects to take into account and if we could add new and remove CAD Image association on a existing WPART in a Released state ?
Dobi
Adding and removing associations to WTParts will require a checkout/check-in so whether that’s allowed in the Released state for you depends on the permissions you have at that state. I would imagine your released state is locked for editing.
7-Bedrock
Error, comment to be deleted.
