Feb 5, 2014 1:02 PM UTC
parts/asm cannot be retrieved
hi
I am having trouble retrieving data from windchill, followed by the massages bellow :
1. The object with the following key was deleted or inaccessible: "wt.epm.EPMDocument
2. Local cache for source "failedRequest" is having incomplete information for merge
3. Local cache contents need to be synchronized with the workspace
does enyone have en idea what could be the problem and how to fix this?
Dec 17, 2014 6:58 PM UTC
Having the same issue and cannot figure out a solution.
Dec 17, 2014 7:21 PM UTC
You can run the below command and check the actual location if the file exists there.
Know the Physical Location
windchill wt.fv.tools.WContentVerify -checkBusinessObject
Feb 19, 2016 6:41 AM UTC
Hello Arpit,
I'm not familiar with "wt.epm.EPMDocument". Could you describe it more clearly? Thanks!
Feb 23, 2016 7:49 PM UTC
Hi Hui Duan,
That's the internal object type name for a CAD file in Windchill.
As for the original post, could it be an access rule thing? Do you have proper access to that file?
PS: I have no idea why it is blocking your name.
