Aug 5, 2025 4:10 PM UTC
PartsLink attributes that are required depending on another attribute
Hi Community,
Is there a way to set a condition in PartsLink 12.0 that works like a "required if"?
So if PartsLink attribute “Type” == “mechanical”, then attributes 1 and 2 must be required.
If PartsLink attribute “Type” == “electrical”, then attributes 3 and 4 must be required.
The AI says that this is available from version 11 onwards, but I can't find anything. Is this a hallucination, or can someone explain to me how to set this up?
Thanks in advance
BR Simon
avillanueva
23-Emerald II
Aug 6, 2025 1:53 PM UTC
https://www.ptc.com/en/support/article/CS285024?source=search
Unfortunately, cascading attributes are not part of classifications.
avillanueva
23-Emerald II
Aug 5, 2025 4:31 PM UTC
I think you are looking for cascading attributes  but based on your type, wouldn't it be easier to just use a node? like this:
Aug 6, 2025 12:14 PM UTC
Thanks for the answer!
I had already considered this option, and it would work well for this simple example. But in more complicated cases, such as product information required due to regulations such as F-Gas. It would be cool to make it required if another field such as “F-gas related” is Yes. Then other attributes pop up or become required.
Are the cascading attributes adjustable within PartsLink or can it be installed in PartsLink too? So that I can run it with Classification attributes on branch and leaf level?
avillanueva
23-Emerald II
