Jun 16, 2014 7:52 PM UTC
Passing Information(objects) within a workflow
I need to pass information from a soft type atribute into a workflow and then back out again. I am not sure on how this can be accomplished. Any advice would be greatly appreicated. I have tried using an expression bot but havent had much luck. I have tired the normalizedObject class but cant it to work.
Kevin
Jun 17, 2014 5:51 AM UTC
What did you do and what exactly didn't work?
You can get information on some workflow step, then store information in workflow variable, and then write where it necessary.
