Aug 19, 2014 6:55 PM UTC
Passing work flow variables to soft type attributes
I have a questions regarding setting documents attributes based on variables in a workflow. I have been able to pull the attributes of a document and set them as variables in a workflow, but was wondering if there is a way to do it in the opposite way? Is there any java code that will work in 10.2 to accomplish this? Lets say I have an approver signature in the workflow( That they filled out in the workflow) I need to take pass that signature back into the soft type?
Oct 26, 2021 5:58 AM UTC
Even I'm trying to achieving the same. Passing variable value to soft type attribute.
Any references.
Durga
Oct 26, 2021 12:59 PM UTC
Hi Durga,
If the mapping is between a workflow and the primary business object then another option for you could be to pass it using an alias attribute, there's examples on PTC support.
