Mar 6, 2015 2:18 AM UTC
Prevent Complete Task if WTdoc is checked out?
I would like to add code to the transitions tab in a workflow that would check to make sure the WTdoc used to initiate the workflow is checked in. If it is not I would like an exemption (pop up) to show telling the user to check in the doc.
Does anyone have code they can share?
Greg
Mar 6, 2015 1:22 PM UTC
Sorry my mistake
if(primaryBusinessObject instanceof wt.doc.WTDocument) {
wt.doc.WTDocument doc = (wt.doc.WTDocument) primaryBusinessObject;
if(wt.vc.wip.WorkInProgressHelper.isCheckedOut(doc))
throw new wt.workflow.WfException("Document " + wt.identity.IdentityFactory.getDisplayIdentifier(primaryBusinessObject) + " in c/o state");
Mar 6, 2015 1:01 PM UTC
Try with this:
if(wt.vc.wipWorkInProgressHelper.isCheckedOut(doc))
GregOlson16-PearlAuthor
Mar 6, 2015 1:15 PM UTC
Seems to have an issue:
Checking Syntax...
D:\PTC\Windchill_10.2\Windchill\temp\WfExpression99618082.java:28: error: cannot find symbol
if(WorkInProgressHelper.isCheckedOut(doc))
symbol: variable WorkInProgressHelper
Note: D:\PTC\Windchill_10.2\Windchill\temp\WfExpression99618082.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
1 error
Syntax check complete.
Sorry my mistake
