Pro/Engineer on a Clustered environment
All,
Is it possible to configure Pro/Engineer to use a specific node of a clustered environment? We have a clustered environment with two servers with multiple forground method servers and one server with two background method servers, all behind a load balancer. We are using three Pro/Engineer workstations to import a large amount of data into Windchill and would like to configure them to use the node that has less traffic on it. I have tried setting the Windchill url to the ip address of one of the nodes, but the upload and download actions will not work.
Thank You,
Paul Hartwig
Ingersoll Rand
In Reply to Paul Hartwig:
All,
Thank You,
Paul Hartwig
Ingersoll Rand
Paul,
You could set a host entry on the workstations, that would then bypass the load balancer and connect to a specific server. Edit the file
C:\windows\system32\hosts
Add a line like
Windchillurl.whatever.com 192.168.0.50
Set a different IP on each workstation
Lewis
