pro_mp_density in windchill 9.1 and 10.1
So as well all know PTC changed the pro_mp_density to a units based attribute a few creo releases ago. When this happened we renamed the old attribute and created a new one. This may or may not been the correct way to handle this. Now during our windchill 10.1 upgrade opening up old models in creo it is throwing a conflict. Which can be ignored but I would like to know how to remove this issue all together. How have other places dealt with this.
Hi Wayne,
We have always designated the Pro/E system parameters PRO_MP_MASS and PRO_MP_DENSITY . When we went from Wildfire 3 to Wildfire 5 these parameters now had units but the same-named attributes in Windchill did not.
To fix this we did the following (Windchill 9.1 M060) which created two new attributes in Windchill; MASS and DENSITY; and mapped them to PRO_MP_MASS and PRO_MP_DENSITY.
Mike Foster
ATK
Type and Attribute Manager
First create a Quantity of Measure
Quantity of Measure Manager
New
Unit: lbs-mass/in**3
Create new attributes with units
Attribute Definition Manager
Select Versioned_Attributes > New Attribute:
Name
Data Type
Qty of Measure
Logical Identifier
Display Name
DENSITY
Real Number with Units
Mass Density
DENSITY
DENSITY
MASS
Mass
MASS
MASS
Add attributes to EPM Document and add mapping
Type Manager
EPM Document > Workgroup Manager CAD Document > Edit (button)
Template (tab) > Highlight "Attribute Root" > Add Attribute > DENSITY, MASS > Units USCS
Attribute Mapping (tab) > Add Mapping > Save > OK > Check in Workgroup Manager CAD Document
Attribute
(new Windchill)
Mapping Context
Mapping
(Pro/E parameter name)
DENSITY
Pro/ENGINEER
PRO_MP_DENSITY
MASS
Pro/ENGINEER
PRO_MP_MASS
PRO_MP_DENSITY
Pro/ENGINEER
PRO_MP_DENSITY
PRO_MP_MASS
Pro/ENGINEER
PRO_MP_MASS
