Apr 28, 2016 8:17 AM UTC
Problem when trying to disable "remove" button
Hi everyone,
I have to make a custom filter to deactivate some buttons when the root part (here the green/yellow cog) was on a specific state.
And when I select the other sub part (pink cog) the button will be disabled because of the root part.
As you can see on the picture, I successfully disable "Insert existing", "Insert new" (and the drop down actions), but I'm still stuck to disable "Remove" action.
What I know :
Create a new custom class filter : (It works !)
public class FilterEditStandartPart extends DefaultSimpleValidationFilter {
     if (root_part.getLifeCycleState().equals(States.RELEASED)) { // I do my test with this state, not the final state I need to use
          status = UIValidationStatus.DISABLED;
Create a service on my "properties.xconf" file and propagate it : (service working)
<Service context="default" name="com.ptc.core.ui.validation.SimpleValidationFilter">
  <Option requestor="null" serviceClass="ext.sogerma.pbs.filters.FilterEditStandartPart" selector="filterEditStandartPart"/>
</Service>
Sample of my "custom-actions.xml" file :
<objecttype name="psb" resourceBundle="com.ptc.windchill.enterprise.part.psb.psbActionsRB">
     <!-- This one works perfectly -->
     <action name="insertExistingPartStructureGWT">
          <command class="com.ptc.cat.gxt.client.action.AdvancedAddAction"/>
          <includeFilter name="com.ptc.cat.ui.client.internal.action.OneSelectionFilter"/>
          <includeFilter name="com.ptc.cat.ui.client.internal.action.IsNotUnspecifiedIterationFilter"/>
          <includeFilter name="com.ptc.cat.ui.client.internal.action.OriginalCopyFilter"/>
          <includeFilter name="disableForAdminLocked"/>
          <includeFilter name="disableForPartToCadBuildAdminLocked"/>
          <includeFilter name="disableForNewObjectInWorkspace"/>
          <includeFilter name="insertExistingPartImplementationChooser"/>
          <includeFilter name="filterEditStandartPart"></includeFilter>
            <supportedTypes>
                <type value="wt.part.WTPart"/>
                <type value="wt.part.WTPartUsageLink"/>
                <type value="wt.part.PartUsesOccurrence"/>
                <type value="wt.part.RTPartPathOccurrence"/>
            </supportedTypes>
    </action>
    <!-- This is my problem, it seem not working or maybe it's override by something else -->
    <action name="removeGWT">
          <command class="com.ptc.windchill.enterprise.part.psb.client.action.PSBRemoveAction"/>
          <includeFilter name="com.ptc.cat.ui.client.internal.action.OneOrMoreSelectionFilter"/>
          <includeFilter name="com.ptc.cat.ui.client.internal.action.IsNotRootStructureModelFilter"/>
          <includeFilter name="com.ptc.cat.ui.client.internal.action.IsNotSummaryRowFilter"/>
          <includeFilter name="com.ptc.cat.ui.client.internal.action.ParentOriginalCopyFilter"/>
          <includeFilter name="com.ptc.windchill.enterprise.part.psb.client.action.ReplacementPartTypeFilter"/>
          <includeFilter name="disableForParentInTreeAdminLocked"/>
          <includeFilter name="disableForPartToCadBuildParentInTreeAdminLocked"/>
          <includeFilter name="disableForNewParentObjectInWorkspace"/>
          <supportedTypes>
              <type value="wt.part.WTPartMaster"/>
              <type value="wt.doc.WTDocument"/>
              <type value="wt.doc.WTDocumentMaster"/>
              <type value="wt.part.WTPartDescribeLink"/>
              <type value="wt.part.WTPartReferenceLink"/>
          </supportedTypes>
    </action>
    <!-- This one works great to disable "Remove" button on the "Uses" tab -->
    <action name="removeChildPartGWT">
          <includeFilter name="disableForTableContextAdminLocked"/>
          <supportedTypes>
          </supportedTypes>
    </action>
</objecttype>
I try to debug the method used on "DefaultSimpleValidationFilter" : public UIValidationStatus preValidateAction(UIValidationKey aValKey, UIValidationCriteria aValCrit) {...}
When I refresh the page or clic on another part, I don't see the "removeGWT" in "aValKey" param.
I see some other I configure and I see the "removeChildPartGWT" when I click on a "Uses" part.
I really need to deactivate this button when the root part was on a specific state, my customer need it to prevent removing part ! (and I can't say him to no click on it )
Do you have an idea of why this not work with "removeGWT" and/or a solution to disable it ?
Thank you.
fmeynardAnswer
Apr 29, 2016 8:39 AM UTC
So with my colleagues, we try to debug "DisableForNewObjectInWorkspaceFilter" to find a "remove" action.
We found "removeServiceModelGWT" and so that the solution.
THE solution : You need to add in your "custom-actions.xml" this part to "catch" the remove structure button in your filter class :
<objecttype name="rulespartseditor" resourceBundle="com.ptc.arbortext.windchill.rulespartseditor.RulesPartsEditorActionsRB">
     <action name="removeServiceModelGWT">
          <command class="com.ptc.arbortext.windchill.rulespartseditor.structure.client.action.RemoveMetaServiceModelAction"/>
          <includeFilter name="com.ptc.arbortext.windchill.rulespartseditor.structure.client.action.OneTreeNodeSelectionFilter"/>
          <includeFilter name="your_Filter_Service_Here"/>
          <supportedTypes>
          </supportedTypes>
     </action>
</objecttype>
Greetings
fmeynard1-VisitorAuthorAnswer
          <supportedTypes>
          </supportedTypes>
     </action>
</objecttype>
Greetings
