May 24, 2023 4:33 PM UTC
Prohibit document publishing
As per the original post.
Is there a way to exclude all wtdocuments from being published regardless of size?  We are dumping thousands of PDF files into the system, when we change state to released they all try to publish and fail... no reason to try and publish a pdf to a pdf.
TomU
May 24, 2023 5:01 PM UTC
SAP01010110-MarbleAuthor
May 25, 2023 2:17 PM UTC
Already saw that article which states preventing "attachments from publishing"... not what i'm asking.  Again as an example... a simple pdf file is in windchill as WIP... when we change state to RELEASED the publisher tries to publish... we want to stop this behavior.
HelesicPetr
May 26, 2023 5:55 AM UTC
Hi @SAP010101
So use another article to stop the publishing if the metadata are changed.
CS74977
This really can help.
PetrH
jbailey
18-Opal
May 25, 2023 4:47 PM UTC
You would likely have to create a publishing rule to exclude that file type
May 25, 2023 9:04 PM UTC
Not sure how to do that... what would be the "authoring-application name" since we're talking about documents not CAD documents?  Or is that handled differently all together?
jbailey
18-Opal
May 25, 2023 10:20 PM UTC
Are you using Livecycle? or ms office publishing?
18-Opal
Jun 16, 2023 8:52 PM UTC
The short answer is YES.
Did you look thru wvs.properties?
The answer is right there.
Dec 7, 2023 8:13 AM UTC
Maybe should open a new thread, but does wvs.properties also answer how to prohibit templates for WTDocument from publishing..?
The "Publish and Thumbnail Control" search does not even recognize the number of the template document I'd want to include in the list or when adding directly says "Publish control not added (check number).
