Nov 25, 2013 4:37 PM UTC
Project resources report in Query Builder
I would like to create a report using the Query Builder (Windchill 10.0 M030) that lists all the resources and the project they are linked to. It could look like this:
Resource NameProject Name
Resource 1Project 1
Resource 1Project 2
Resource 2Project 1
Resource 3Project 3
Thank you !
May 3, 2016 10:52 AM UTC
Hello Florent,
were you able to solve this issue. If yes, is it possible to share the details.
Regards
Syed
MarcoTosin
May 3, 2016 1:45 PM UTC
Hello Syed,
if you haven't already done, I suggest you to join this group Reporting and to take a look at this document Resource for reporting
In this document you can find some helpful information about reporting and also lots of report ready to use.
Maybe you won't find what you're looking for, but I hope it can helps you.
Marco
May 11, 2016 10:59 AM UTC
Thank Marco for the response. I am already aware of the above resource. Somehow the report shows blank after generation. So wanted to check if this worked earlier.
