Dec 8, 2023 3:13 PM UTC
Promotion Request Participant List Table is Blank
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.10
When creating a promotion request, selecting certain workflow processes on the "Select Participants" step results in the "Participant List" showing a completely blank table, regardless of the table view selected. The roles of the related workflow are not present and users are not selectable. Other workflow processes work properly. This issue does NOT occur if the user is in the Product Manager role. Need to determine the cause.
No errors observed in MethodServer logs at time of creating the issue.
    Dec 11, 2023 3:08 PM UTC
    Actually I found the problem.  This system has custom ACLs and there was one missing in the \Private\System domain of the Product context to allow Read and Modify access at "Principal" level.  This fixed the issue when it was added back in, compared to another product context which had this ACL and did NOT have this issue.
    avillanueva
    23-Emerald II
    Dec 11, 2023 2:49 PM UTC
    Do you have any screen shots to help us see what you are seeing?
    RS_1009568512-AmethystAuthorAnswer
