Promotion request status REJECTED
Hi
We are facing some issues with promotion status.
After the promotion request is approved, Promotion request status changed as REJECTED and vote showing as approved.
Refer the image for details.
Any idea?
Thank you
Sathish Rosario
22-Sapphire I
July 11, 2022
Yes, very likely it's the validation code that is sending the workflow process down the Reject path.
this could happen for example if the data has been checked out / changed / checked back in after the Promotion Request was created, resulting in the Promotion Request not acting on the latest version (which could happen if the Lock transition is not used in the lifecycle or if the permissions at the Lock state do not prevent check out.
joe_morton
You'd want to check the Workflow Process Manager. I believe the out-of-the-box promotion workflow has some validation check at the end, and if the promoted items fail the validation, it will set the promotion to Rejected.
22-Sapphire I
July 11, 2022
Thank you for your reply.
The case as below:
Object last check in (iteration increased)     : 2022-07-01 08:47 IST
Promotion request created                             : 2022-07-04 10:33 IST
Promotion request completed                       : 2022-07-07 17:39 IST
Object latest check in (iteration increased): 2022-07-08 10:19 IST
My suspect is, the object may be checked out between 2022-07-04 10:33 IST and 2022-07-07 17:39 IST.
After modifications, object may be checked in on 2022-07-08 10:19 IST.
Now, how do I know, when the object was last checked out?
Thank you
Sathish Rosario
