Jul 7, 2025 9:25 AM UTC
promotion request window doesn't popup automatically
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 CPS30
After checkin via stand alone Edge browser a promotion request window doesn't popup automatically.
    Fadel
    23-Emerald II
    Jul 7, 2025 11:48 AM UTC
    do you see that accorss all browsers ? any errors in logs ?
    Buiꓘa
    Jul 14, 2025 11:03 AM UTC
    In which log file should I have a look?
    It works fine with the embedded browser, but not with the stand alone browser.
    avillanueva
    23-Emerald II
    Jul 14, 2025 11:14 AM UTC
    Errors would appear in Methodserver logs. There might be multiple running so you might have to check each on about the time of check in. If you are expecting a popup, are popup blockers off?
