Aug 1, 2023 2:56 PM UTC
providing sql server cluster information windchill pdm
Hi all,
We have a sql server cluster set up and trying to connect to it thru PSI. Database is created as well.
Is there any specific format to fill up the
1) sql server cluster network name:
2) Installed sql server instance (named instance)
anybody if kindly can provide some help/insights will be really helpful to unblock me
Thanks all
Raj
Aug 15, 2023 5:16 PM UTC
Resolved with help of our SQL DBA
Thanks all for the help
Community Moderator
Aug 10, 2023 9:22 PM UTC
Hi Raj,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
RW_1068286012-AmethystAuthorAnswer
