Psi fails as Error during schema creation, while adding columns. See the logs for more information.
- 1 reply
- 1553 views
- Translate All
Hi All,
Please help me to solve the following issue.
INFO 2021-03-03 17:14:11 - Schema validation successful. Updates will attempt to proceed.
INFO 2021-03-03 17:14:11 - Updating database schema... be patient.
INFO 2021-03-03 17:14:46 - Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=128m; support was removed in 8.0
INFO 2021-03-03 17:14:46 - joining with std out thread
INFO 2021-03-03 17:14:46 - std out join complete.
INFO 2021-03-03 17:14:46 - joining with std error thread
INFO 2021-03-03 17:14:46 - std err join complete.
FATAL 2021-03-03 17:14:46 - AddColumns -u -s process returned non-zero: 1
DEBUG 2021-03-03 17:14:47 - Installation is Aborting. The installation cannot continue.
FATAL 2021-03-03 17:14:53 - Aborting installation.
FATAL 2021-03-03 17:14:53 - Installation is Aborting. The installation cannot continue.
FATAL 2021-03-03 17:14:53 - Error during schema creation, while adding columns. See the logs for more information.
FATAL 2021-03-03 17:14:53 - aborting: original exit_code = 2
FATAL 2021-03-03 17:14:53 - aborting: normalized exit_code = 2
DEBUG 2021-03-03 17:14:54 - SHUTDOWN REQUESTED
DEBUG 2021-03-03 17:14:54 - (X) commiting registry
DEBUG 2021-03-03 17:14:55 - (X) shutting down service manager
DEBUG 2021-03-03 17:14:58 - (X) cleaning up temporary directories
DEBUG 2021-03-03 17:14:58 - Exiting with exit code: 2
DEBUG 2021-03-03 17:15:04 - cleanUp()
DEBUG 2021-03-03 17:15:04 - calling cleanUpWin32()
