Dec 29, 2021 4:30 AM UTC
PSI fails with Connnection to the database failed or SCU failed to execute the query.
I'm Trying to install 12.0.2 with following configuration
OS: Windows Server 2019 standard
DB: SQL 2018
PSI fails with Error Connnection to the database failed or SCU failed to execute the query. </p>.
ERROR MESSAGE: Database 'wc' does not exist. Make sure that the name is entered correctly
The IP is static, Firewall is off, Installation is D:\
Any suggestions welcomed.
Durga
Dec 29, 2021 7:35 AM UTC
 Hi Durga,
Read the following articles:
