PTC Live TCs registration is now open
  • May 22, 2014
  • 0 replies
  • 630 views
The TCs registration for PTC Live in Boston is now open.
To start the registration process, please log into the TC area of our PTC/USER portal; i.e., to http://portal.ptcuser.org/p/st/ld/&sid=s2_007_tc. Then, go to your TC page (for Product Analytics, you should go to Windchill Solutions TCs) You might need to request to join the group if you have not already done so. You should be able to select Members Only pull down on the right hand of the screen. Select the My Communities menu. Then select the Technical Committees (TCs) button. You should then see an events section with a registration button. You will then be able to build an agenda for the TCs.
If you have any questions, please do not hesitate to contact me.
Jim
