May 3, 2018 12:20 PM UTC
PTC System Monitor 6.0 error during installation
While installing PSM 6.0, an error appears:  PAAgent service error=2, No such file or directory.
Error log:
DEBUG  2018-05-03 13:09:39 - PAAgentInstaller start
DEBUG  2018-05-03 13:09:40 - isAgentConfigSkipped false
DEBUG  2018-05-03 13:09:40 - Configuration path: /opt/psm6/PSM/PAAgent
DEBUG  2018-05-03 13:09:40 - Validation for Dashboards installation starts
DEBUG  2018-05-03 13:09:40 - >>
DEBUG  2018-05-03 13:09:40 - curl home exists at /usr/bin/curl
DEBUG  2018-05-03 13:18:06 - Cannot run program "/opt/psm6/PSM/PAAgent/paagent_daemon.sh": error=2, No such file or directory
DEBUG  2018-05-03 13:18:06 - PAAgentInstaller finished
DEBUG  2018-05-03 13:18:07 - Retrying Installables deferred in pass 0
DEBUG  2018-05-03 13:18:07 - From Pass 0: com.zerog.ia.installer.actions.ASCIIFileManipulator -- Modifying: paagent_daemon.sh
DEBUG  2018-05-03 13:18:07 - Installer: pass 1: deferred: com.zerog.ia.installer.actions.ASCIIFileManipulator -- Modifying: paagent_daemon.sh
DEBUG  2018-05-03 13:18:07 - Deferral retries done because:
DEBUG  2018-05-03 13:18:07 - No retries succeeded.
DEBUG  2018-05-03 13:18:08 - Installation encounter an error :
I did clear the Enable Performance Advisor check box and i have read that eventhough the performance Advisor will be instralled. But why ist the directory to paagent_daemon.sh unavailable. After the failed installation, I have checked the installed forlder and saw that paagent_daemon.sh  in an exsiting directory. What can be the problem?
Please help
Thank you 🙂
    May 7, 2019 8:32 AM UTC
    Hello nh_y,
    Can you please share the full log file?
    Yassine
