Feb 20, 2017 4:47 PM UTC
Publish Additional file DXF under parameter condition
Dear All
I need to understand if is possible enable the worker to publish also the DXF format for the Drawing but only  under parameter condition.
My idea is define a boolen parameters on EPM Document like   DXF_Publish   TRUE/FALSE and the make the system
able to publish r  DXF file if the above parameter  was set TRUE.
Thanks to everybody  have the solution
Beniamino
2-Explorer
Feb 20, 2017 9:46 PM UTC
This is possible, I haven't tried this, but it should work
  1. Create a parameter from drawing template.
  2. Designate the parameter to an IBA in the EPMDocument type or subtype
  3. Configure publish rules to evaluate the value of IBA and publish the additional file type - Look at Step#3 from here - http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=WVSPublishRulesEvaluate&action=show
