Aug 30, 2024 9:32 AM UTC
Publish files created with Autocad with Creo publisher
Version: Windchill 12.0
Use Case: Publish dwg files
Description:
Is it possible to use the same Creo file publisher for dwg generated by Autocad with Windchill integration? I wouldn't want to install an Autocad on the Windchill server! Thank you
Aug 30, 2024 10:48 AM UTC
Hi Nino,
Give a brief description of the software you were using, the format type you desire, and the output file you need.
Aj
Aug 30, 2024 11:19 AM UTC
I use Windchill 12.0.2.4 and Creo 8.0.9.0.
In addition to 18 Creo licenses we have recently also integrated 2 AutoCad licenses on Windchill, what I would like to achieve is the conversion into files viewable with Navigator like those of Creo.
Example
I would not like to install a copy of AutoCad on the Windchill server to use as a Worker but use the already present copy of Creo!
Aug 30, 2024 12:19 PM UTC
Hi Nino,
First make it simple if we are using Creo mean, format is .asm, .prt, .drw.
for example I want dwg/dxf file that i want from .drw format mean we can use "Visualization Configuration" that'll convert automatically dwg/pdf save it Representations/Annotation. Right click and open in Creo View.
AutoCAD doesn't want any CAD Worker to publish it'll automatically publish. But if you want direct native AutoCAD file dwg/dxf and also you want edit and modify mean you need a AutoCAD Software.
Aj
