Feb 10, 2026 12:44 PM UTC
Publish Job Failed - WVS Job Monitor
Version: Windchill 13.1
Use Case: Hi everyone, I have some troubles with publishing in windchill. Whenever I click the thumbnail of CAD part, there were a popup "Sent To Publisher: Select WVS Job Monitor for job status". And then I'm getting status Job Failed. Can anyone please help me how to fix it? I could'nt see any preview in my thumbnail and I couldn't directly opened it in Creo View because the status Job is still Failed
Description:
Job Log below:
10 Feb 2026 19.34.01:Start Job: CAD Part - 3dmodel.prt, 1.2
10 Feb 2026 19.34.01:make temp dir $(publish.tempdir)\publish11428478569884603681.tmp
10 Feb 2026 19.34.01:The EPMDocument Default Config Spec was selected as the default
10 Feb 2026 19.34.02:Start: CAD Part - 3dmodel.prt, 1.2
10 Feb 2026 19.34.02:Authoring Application: Creo
10 Feb 2026 19.34.02:Using Publish Rule version.xml from context Site
10 Feb 2026 19.34.02:Transferring Files to: $(publish.tempdir)\publish11428478569884603681.tmp
10 Feb 2026 19.34.02:error getting primary content
10 Feb 2026 19.34.02:Attempting to delete temporary workspace publish11428478569884603681.tmp.
10 Feb 2026 19.34.04:Done deleting temporary workspace publish11428478569884603681.tmp.
10 Feb 2026 19.34.04:Error getting content
10 Feb 2026 19.34.04:End (with Error): CAD Part - 3dmodel.prt, 1.2
10 Feb 2026 19.34.05:End job (with error): CAD Part - 3dmodel.prt, 1.2
10 Feb 2026 19.34.05:Publish Complete event dispatched
10 Feb 2026 19.34.05:remove temp dir: $(publish.tempdir)\publish11428478569884603681.tmp
avillanueva
23-Emerald II
Feb 10, 2026 12:52 PM UTC
Is the CAD worker on same machine as Windchill? Was this working previously and are other object able to be published? If its just this model, then is there anything that makes it special?
See if you see this message in Background MS logs:
https://www.ptc.com/en/support/article/CS327839?source=search
Are you using remote file vaults?
https://www.ptc.com/en/support/article/CS445951?source=search
Could be related to user that is publishing content:
https://www.ptc.com/en/support/article/CS373529?source=search
avillanueva
23-Emerald II
Feb 10, 2026 5:12 PM UTC
Hi! Thank you for your response. I just add the author properties like in this link: https://www.ptc.com/en/support/article/CS373529?source=search. And i try again to run the wvs, at first i got the "EXECUTING" status. But after waiting several minutes, it become "JOB FAILED" with this job log:
Job Log
11 Feb 2026 00.00.27:Start Job: CAD Part - 3dmodel.prt, 1.3
11 Feb 2026 00.00.28:make temp dir $(publish.tempdir)\publish6198504506425703626.tmp
11 Feb 2026 00.00.28:The EPMDocument Default Config Spec was selected as the default
11 Feb 2026 00.00.28:Start: CAD Part - 3dmodel.prt, 1.3
11 Feb 2026 00.00.28:Authoring Application: Creo
11 Feb 2026 00.00.28:Using Publish Rule version.xml from context Site
11 Feb 2026 00.00.28:Transferring Files to: $(publish.tempdir)\publish6198504506425703626.tmp
11 Feb 2026 00.00.29:Number of Files (identified to be) Transferred: 1
11 Feb 2026 00.00.29:Creo Part Conversion
11 Feb 2026 00.00.30:Added request to PROE queue
11 Feb 2026 00.00.30:No available connected worker
11 Feb 2026 00.00.30:Starting new worker lab01.caditlab.local-PROE:1, attempt 1 of 3
11 Feb 2026 00.02.13:Timeout exceeded waiting for a reply from the CadAgent - Time out 103 seconds
11 Feb 2026 00.02.17:No available connected worker
11 Feb 2026 00.02.17:Starting new worker lab01.caditlab.local-PROE:1, attempt 2 of 3
11 Feb 2026 00.03.58:No available connected worker
11 Feb 2026 00.03.58:Starting new worker lab01.caditlab.local-PROE:1, attempt 3 of 3
11 Feb 2026 00.05.40:No available connected worker
11 Feb 2026 00.05.40:No worker can be started, removing request from queue
11 Feb 2026 00.05.40:Part Processing Returned: $ERROR$ No worker can be started, removing request from queue
11 Feb 2026 00.05.40:Attempting to delete temporary workspace publish6198504506425703626tmp.
11 Feb 2026 00.05.40:Done deleting temporary workspace publish6198504506425703626tmp.
11 Feb 2026 00.05.40:CadAgent Returned: $ERROR$ No worker can be started, removing request from queue
11 Feb 2026 00.05.40:End (with Error): CAD Part - 3dmodel.prt, 1.3
11 Feb 2026 00.05.40:End job (with error): CAD Part - 3dmodel.prt, 1.3
11 Feb 2026 00.05.40:Publish Complete event dispatched
11 Feb 2026 00.05.41:remove temp dir: $(publish.tempdir)\publish6198504506425703626.tm
avillanueva
23-Emerald II
Feb 10, 2026 5:15 PM UTC
Looks like you are getting a new error. I had some other questions in my post. Was this working before or is this first time setup issues?
