Mar 22, 2016 12:18 PM UTC
Publish rules based on EPM Document Name
Looking for ideas to publish objects different from regular publishing output with specific file names.
Say if object name with MANF Ex: 12190242-MANF-00A.drw, this need to publish additional or different output from the regular publishing.
Let me know.
Murthi
2-Explorer
Mar 22, 2016 2:28 PM UTC
You can add a regular expression in your publishing rule,similar to the highlighted one. You can ignore the rest of the rules, we have that to publish DRW as a pdf and store it as a WTDocument in published content directory
<rules xmlns="http://www.ptc.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.ptc.com/PublishRulesSchema.xsd">
<authoring-application name="PROE">
<additional-files name="DrawingPDF">
<file display-label="PDF" type="pdf" default="true" output-prefix="pdf"/>
</additional-files>
<param-set name="Share with WTDocumentReleased Drawing">
<post-publish name="delegate">com.ptc.wvs.server.publish.AdditionalFilesPostPublishDelegate</post-publish>
<post-publish name="published-content-link">create</post-publish>
<post-publish name="name">{EPM_NAME}</post-publish>
<post-publish name="lifecycle-state">RELEASED</post-publish>
<post-publish name="lifecycle-template">Basic</post-publish>
<post-publish name="type">com.companyname.publishedContent</post-publish>
<post-publish name="folder">/Published Contents</post-publish>
<post-publish name="additional-file-primary">.*\.pdf</post-publish>
</param-set>
<condition name="IS_Released_Drawing">
<attribute name="epmdoc_name" regex=".*\.drw" />
<attribute name="epmdoc_lifeCycleState" value="Released"/>
</condition>
<if condition="IS_Released_Drawing">
<publish evaluate-rules-on-republish="true"  additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="create-representation"/>
<publish evaluate-rules-on-republish="true"  additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="schedule"/>
<publish evaluate-rules-on-republish="true"  additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="checkin"/>
<publish evaluate-rules-on-republish="true"  additional-files="DrawingPDF" param-set="Share with WTDocumentReleased Drawing" on="unknown-source"/>
</if>
<publish evaluate-rules-on-republish="true" on="checkin"/>
<publish evaluate-rules-on-republish="true" on="create-representation"/>
<publish evaluate-rules-on-republish="true" on="schedule"/>
<publish evaluate-rules-on-republish="true" on="unknown-source"/>
</authoring-application>
</rules>
Thank you,
Binesh Kumar
Medtronic - MITG
taruchamy12-AmethystAuthor
Mar 23, 2016 12:39 PM UTC
Thanks Binesh Kumar‌
Will try this...
Apr 5, 2016 5:13 AM UTC
Thanks Tom and Binesh.
\bISPL\b failed to search for the intended object though. But And condition works fine.
I did achieved this with
<attribute name="epmdoc_number" regex= ".*(?i:ispl).*\.DRW" />
Where I could create additional file type, but still searching for the rule to alternate file type [By Default I have defined DXF for all the drawings] - I need to replace with TIF for drawings containing ISPL.
Oct 14, 2016 2:34 PM UTC
Dear all,
Any ideas how to get this working on 10.1?
Thanks in advance.
Gautham
