Publisher error
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.4 Files are not publishing even though publisher is running, and shared folder access is also working while manually checking from both systems (Publisher and Windchill server) Here are the errors that I faced 2026-08-26 10:53:14: Starting worker test 2026-08-26 10:53:14: Added request to INVENTOR queue 2026-08-26 10:53:15: Test job for Worker: A01SR00704.ROOP.COM-INVENTOR:1 2026-08-26 10:53:15: Processing work order 2026-08-26 10:53:15: Deleting all files from \\A01sr00704\CAD_SHARED2\w2i1j2 2026-08-26 10:53:15: Successfully deleted all files 2026-08-26 10:53:15: Creating directory \\A01sr00704\CAD_SHARED2\w2i1j2 2026-08-26 10:53:15: Problem creating directory \\A01sr00704\CAD_SHARED2\w2i1j2. It already exists as a file 2026-08-26 10:53:15: Problem creating directory \\A01sr00704\CAD_SHARED2\w2i1j2. Do not have write access 2026-08-26 10:53:15: Worker test returned an error message 2026-08-26 10:53:15: Unable to submit job to worker 2026-08-26 10:53:15: Problem creating directory \\A01sr00704\CAD_SHARED2\w2i1j2. Do not have write access
18-Opal
If the share is already working fine then maybe the share path has to be added to worker whitelist property, check the article as it’s a different property name depending on the Windchill version
Dobi
Your error is saying that your account - whatever the account that is doing the publishing - doesn’t have write access to your shared folder. This is most likely an issue with whatever your worker monitor logon account is whether that has adequate access to the shared folder. Could be a network/domain issue as well.
