Dec 10, 2012 6:45 PM UTC
Publishing CAD files to different files types in Windchill 10.1
I'm looking to publish Creo drawings to PDF and DXF and publish parts/assemblies to CreoView and STEP... The documentation goes over how to sort by epm-type in the publishing rules but all the "CAD Documents" are of a single epm type. They are further sorted by document category (i.e. "CAD Part" or "Drawing") within the epm type of "CAD Document" but I can figure out if it's possible or not to sort by document category. Anyone been able to do this?
Thanks!
Dec 20, 2012 5:41 PM UTC
After a lot of trial and error I figured out the solution to my problem. My publisher rules file looks like the following now:
<?xml version="1.0" encoding="UTF-8"?>
<rules xmlns="http://www.ptc.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.ptc.com PublishRulesSchema.xsd" evaluate-rules-on-republish="true">
<authoring-application name="PROE">
<additional-files name="drawing_files">
<!--only default='true' files will be generated at this time -->
<file display-label="PDF" type="pdf" default="true" output-prefix="pdf" />
<file display-label="DXF" type="dxf" default="false" output-prefix="dxf" />
</additional-files>
<additional-files name="part_files">
<file display-label="STEP" type="step" default="true" output-prefix="step" />
<file display-label="IGES" type="iges" default="false" output-prefix="iges" />
</additional-files>
<additional-files name="asm_files">
<file display-label="STEP" type="step" default="false" output-prefix="step" />
</additional-files>
<condition name="is_drawing">
<attribute name="epmdoc_name" regex=".*\.drw" />
</condition>
<condition name="is_part">
<attribute name="epmdoc_name" regex=".*\.prt" />
</condition>
<condition name="is_asm">
<attribute name="epmdoc_name" regex=".*\.asm" />
</condition>
<!-- Following conditions are evaluated based on the order they appear in this file -->
<if condition="is_drawing">
<publish on="checkin" display-label="Publish drawing - checkin" additional-files="drawing_files" />
<publish on="create-representation" display-label="Publish drawing" additional-files="drawing_files" />
</if>
<if condition="is_part">
<publish on="checkin" display-label="Publish part - checkin" additional-files="part_files" />
<publish on="create-representation" display-label="Publish part" additional-files="part_files" />
</if>
<if condition="is_asm">
<publish on="checkin" display-label="Publish assembly - checkin" additional-files="asm_files" />
<publish on="create-representation" display-label="Publish assembly" additional-files="asm_files" />
</if>
</authoring-application>
</rules>
AndrewDrenner1-VisitorAuthorAnswer
</additional-files>
</additional-files>
</additional-files>
</condition>
</condition>
</condition>
</if>
</if>
</if>
</rules>
Apr 16, 2014 4:35 AM UTC
For my opinion better condition is:
<attribute name="epmdoc_CADName" regex=".*\.drw" />
</condition>
<attribute name="epmdoc_CADName" regex=".*\.prt" />
</condition>
<attribute name="epmdoc_CADName" regex=".*\.asm" />
</condition>
TomU
Apr 16, 2014 2:53 PM UTC
Instead of using "epmdoc_name" or "epmdoc_CADName", why not use "epmdoc_docType"?
For example:
<condition name="Valid_Creo_Type">
<or>
<attribute name="epmdoc_docType" value="Assembly"/>
<attribute name="epmdoc_docType" value="Drawing"/>
<attribute name="epmdoc_docType" value="Drawing format"/>
<attribute name="epmdoc_docType" value="Layout"/>
<attribute name="epmdoc_docType" value="Part"/>
</or>
</condition>
