Oct 4, 2023 7:19 PM UTC
Publishing creo drawing as pdf with image embedded on it
When I check in a Creo drawing that has images embedded on it, the published pdf does not show images (though the pdf shows only Creo entities). Is their a solution I can implement, thanks
Oct 5, 2023 3:51 AM UTC
 As there is only .jpeg embedded images can be seen in pdf, so you need to remove the existing image and rename it to with .jpeg extension. And then try below steps:
  • Copy the .jpeg image file into Microsoft Word Document and save it to local disc
  • In Creo Parametric, navigate to Insert-->Object--> Create from file and select the Word document created in the above step
  • Check-in the drawing and publish it
    Article CS98656, for more information
