7-Bedrock
Jun 20, 2022 6:37 AM UTC
publishing failes
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.2
I have published epmdocument through below API and there are no erros on MethodServer logs but got below exception on wvs job logs.
Publisher.doPublish(false, true, objRef, (wt.vc.config.ConfigSpec)null, (wt.vc.config.ConfigSpec)null, true, "MyRep2", "My Description", com.ptc.wvs.common.ui.Publisher.EPM, null, 0);
Here are the errors that I faced
Jun 17, 2022, 7:37:10 AM:Start Job: Drawing - XXX.drw, 0.1
Jun 17, 2022, 7:37:10 AM:make temp dir E:\Ptc\Windchill_12.0\Windchill\temp\pubtemp\publish17031557040286648451.tmp
Jun 17, 2022, 7:37:10 AM:Start: Drawing - XXX.drw, 0.1
Jun 17, 2022, 7:37:10 AM:Preconverted input file missing: 1655451429903-3850786598504160095.pdf
Jun 17, 2022, 7:37:10 AM:End (with Error): Drawing - XXX.drw, 0.1
Jun 17, 2022, 7:37:10 AM:End job (with error): Drawing - XXX.drw, 0.1
Jun 17, 2022, 7:37:10 AM:Publish Complete event dispatched
Jun 17, 2022, 7:37:10 AM:remove temp dir: E:\Ptc\Windchill_12.0\Windchill\temp\pubtemp\publish17031557040286648451.tmp
Jun 20, 2022 3:29 PM UTC
Have you looked at this case?
https://www.ptc.com/en/support/article/CS45408
