Nov 26, 2014 2:27 AM UTC
Publishing Issue
Hi!
Can somebody help me how to publish .dwg drawing in windchill?., because when I'm upload .dwg drawing in windchill the visualization of the drawing is not working.
Thanks!
TomU
TomUAnswer
Nov 26, 2014 2:37 AM UTC
There is not a Creo View adapter that is capable of publishing DWG (or DXF) files. Fortunately, one isn't needed since Creo View can open these files directly. The trick is to tell Windchill that the data has already been published and to just create the thumbnail. Full instructions can be found here:
Automatically generate representation for pre-converted files (CS36856)
Here are the commands I ran on my system to do this very thing: (10.2 M020)
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..DWG=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..DXF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..PDF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..BMP=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..JPG=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..TIF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..GIF=DUMMY,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..PVZ=DUMMY,type=zip,preconverted=true
xconfmanager -t codebase/WEB-INF/conf/wvs.properties -s worker..EDZ=DUMMY,type=zip,preconverted=true
xconfmanager -p
After making the changes you will need to stop Windchill, clear the Tomcat caches, and restart.
TomU
TomU23-Emerald IVAnswer
xconfmanager -p
Luar1-VisitorAuthor
Nov 26, 2014 3:20 AM UTC
Hi Tom.
Thanks for the help. Where is the path to clear the tomcat cache?
<Windchill_Home>\tasks\codebase\com\infoengine\compiledTasks
I will delete the folder inside complied tasks?
Thanks!
TomU
Nov 26, 2014 12:00 PM UTC
There are two folders to delete. I have these lines in a .bat file:
echo off
RMDIR E:\ptc\Windchill_10.2\Windchill\tomcat\instances /Q /S
RMDIR E:\ptc\Windchill_10.2\Windchill\tasks\codebase\com\infoengine\compiledTasks /Q /S
