Publishing Job to Re-publish Only Drawings
Hi guys, I have a scenario where I have all drawings currently published as a PDF. I am switching to HPGL for the primary publishing (so we can use markups,measurements etc) and will be using the "Additionals Files" mechanism for PDF and DXF.
Now the issue is that I need to republish all of the existing drawing and I would rather not republish ALL existing CAD Data.
Running WC 10.1 M040
I'm hoping there is an easy way to run a job like this.
Thanks!
Steve
Thanks!
Steve
