18-Opal
Publishing Job Triggering the Publish Complete Event Twice
I have a case where a publishing job is emitting the Publish Complete event twice within the same job.
I have attached the job log below. Has anyone come across a similar use case or issue?
Nov 30, 2026, 2:47:32 PM:Start Job: Drawing  - xyz.drw, 0.2
Nov 30, 2026, 2:47:32 PM:make temp dir $(publish.tempdir)/publish8297917183760428779.tmp
Nov 30, 2026, 2:47:32 PM:Using passed EPMDocConfigSpec for ConfigSpec
Nov 30, 2026, 2:47:32 PM:Start: Drawing  - xyz.drw, 0.2
Nov 30, 2026, 2:47:32 PM:Authoring Application: Creo
Nov 30, 2026, 2:47:32 PM:Using Publish Rule PublishRules-Quick_View.xml from context Site
Nov 30, 2026, 2:47:32 PM:Transferring Files to: $(publish.tempdir)/publish8297917183760428779.tmp
Nov 30, 2026, 2:47:33 PM:Number of Files (identified to be) Transferred: 10
Nov 30, 2026, 2:47:33 PM:Creo Drawing Conversion
Nov 30, 2026, 2:47:33 PM:Added request to PROE queue for publish queue set XYZ.
Nov 30, 2026, 2:47:33 PM:No available connected worker
Nov 30, 2026, 2:47:33 PM:Starting new worker xyz-2-PROE:1, attempt 1 of 10
Nov 30, 2026, 2:47:43 PM:Job 152 submitted to worker: xyz-2-PROE:1
Nov 30, 2026, 2:47:43 PM:LOGID: worker_88.log
Nov 30, 2026, 2:47:43 PM:Registering Server
Nov 30, 2026, 2:47:44 PM:Downloading xyz.drw
Nov 30, 2026, 2:47:46 PM:Loading xyz.drw
Nov 30, 2026, 2:47:52 PM:Failure to retrieve xyz.drw name xyz (err = -4)
Nov 30, 2026, 2:47:52 PM:Drawing Processing Returned: $ERROR$ Failure to retrieve xyz.drw name xyz (err = -4)
Nov 30, 2026, 2:47:52 PM:Attempting to delete temporary workspace publish8297917183760428779tmp.
Nov 30, 2026, 2:47:53 PM:Done deleting temporary workspace publish8297917183760428779tmp.
Nov 30, 2026, 2:47:53 PM:CadAgent Returned: $ERROR$ Failure to retrieve xyz.drw name xyz (err = -4)
Nov 30, 2026, 2:47:53 PM:End (with Error): Drawing  - xyz.drw, 0.2
Nov 30, 2026, 2:47:53 PM:End job (with error): Drawing  - xyz.drw, 0.2
Nov 30, 2026, 2:47:53 PM:Publish Complete event dispatched
Nov 30, 2026, 2:47:53 PM:remove temp dir: $(publish.tempdir)/publish8297917183760428779.tmp
Nov 30, 2026, 2:47:53 PM:Start Job: Drawing  - xyz.drw, 0.2
Nov 30, 2026, 2:47:53 PM:make temp dir $(publish.tempdir)/publish17747124931920816128.tmp
Nov 30, 2026, 2:47:53 PM:Using passed EPMDocConfigSpec for ConfigSpec
Nov 30, 2026, 2:47:53 PM:Start: Drawing  - xyz.drw, 0.2
Nov 30, 2026, 2:47:53 PM:Authoring Application: Creo
Nov 30, 2026, 2:47:53 PM:Using Publish Rule PublishRules-Quick_View.xml from context Site
Nov 30, 2026, 2:47:53 PM:Transferring Files to: $(publish.tempdir)/publish17747124931920816128.tmp
Nov 30, 2026, 2:47:54 PM:Number of Files (identified to be) Transferred: 10
Nov 30, 2026, 2:47:54 PM:Creo Drawing Conversion
Nov 30, 2026, 2:47:54 PM:Added request to PROE queue for publish queue set XYZ.
Nov 30, 2026, 2:47:54 PM:No available connected worker
Nov 30, 2026, 2:47:54 PM:Starting new worker xyz-2-PROE:1, attempt 1 of 10
Nov 30, 2026, 2:48:15 PM:Job 153 submitted to worker: xyz-2-PROE:1
Nov 30, 2026, 2:48:15 PM:LOGID: worker_89.log
Nov 30, 2026, 2:48:15 PM:Registering Server
Nov 30, 2026, 2:48:16 PM:Downloading xyz.drw
Nov 30, 2026, 2:48:16 PM:Loading xyz.drw
Nov 30, 2026, 2:48:25 PM:Failure to retrieve xyz.drw name xyz (err = -4)
Nov 30, 2026, 2:48:25 PM:Drawing Processing Returned: $ERROR$ Failure to retrieve xyz.drw name xyz (err = -4)
Nov 30, 2026, 2:48:26 PM:Attempting to delete temporary workspace publish17747124931920816128tmp.
Nov 30, 2026, 2:48:26 PM:Done deleting temporary workspace publish17747124931920816128tmp.
Nov 30, 2026, 2:48:26 PM:CadAgent Returned: $ERROR$ Failure to retrieve xyz.drw name xyz (err = -4)
Nov 30, 2026, 2:48:26 PM:End (with Error): Drawing  - xyz.drw, 0.2
Nov 30, 2026, 2:48:26 PM:End job (with error): Drawing  - xyz.drw, 0.2
Nov 30, 2026, 2:48:26 PM:Publish Complete event dispatched
Nov 30, 2026, 2:48:26 PM:remove temp dir: $(publish.tempdir)/publish17747124931920816128.tmp
