Oct 4, 2016 8:17 AM UTC
Publishing not happening between set states?
When we change the status of drawing, the worker doesn't publish the drawing. This was not the behavior before and we have to manually click on the thumbnail to create the representation. Could someone  provide me inputs as to where to begin investigating the cause of this issue.
22-Sapphire I
Oct 4, 2016 3:07 PM UTC
Here are some related articles CS43043, CS238377, CS229067, CS55087.
Unfortunately it's fairly complex.
Oct 6, 2016 7:08 AM UTC
Change the publish.republishondocumentchange & publish.republishonepmdocumentchange to true in WVS.propeties.
Shreyas
jfrancis1-VisitorAuthor
Oct 6, 2016 7:55 AM UTC
these properties have been set to true
Oct 17, 2016 8:19 AM UTC
Can publishing be handled through code?
HelesicPetr
Nov 2, 2016 3:32 PM UTC
You can use the following code in a Promotion Request workflow in expresion robot in the end.
The code sends the EPM documents to publish queue
try
    //create publisher action -  action string .... M queue
    com.ptc.wvs.common.ui.PublisherAction pa = new com.ptc.wvs.common.ui.PublisherAction(com.ptc.wvs.common.ui.PublisherAction.QUEUEPRIORITY, "M");
    //check all target objects
    wt.fc.QueryResult promotables = wt.maturity.MaturityHelper.getService().getBaselineItems((wt.maturity.PromotionNotice)primaryBusinessObject);
    while (promotables.hasMoreElements())
        Object obj = (Object) promotables.nextElement();
        if (obj instanceof wt.epm.EPMDocument)
            wt.epm.EPMDocument epmdoc = (wt.epm.EPMDocument) obj;
            //Find the latest version of document!!!
            wt.vc.config.ConfigSpec configSpec =  wt.vc.config.ConfigHelper.service.getDefaultConfigSpecFor(wt.epm.EPMDocument.class);
            wt.fc.QueryResult qr =  wt.vc.config.ConfigHelper.service.filteredIterationsOf(epmdoc.getMaster(), configSpec);
            if (qr != null)
                while (qr.hasMoreElements())
                    epmdoc = (wt.epm.EPMDocument)qr.nextElement();
            //check the EPMDocument object
            java.lang.String objRef;
            objRef = wt.fc.ObjectReference.newObjectReference(epmdoc).toString();
            //Create publisher
            com.ptc.wvs.common.ui.Publisher pub = new com.ptc.wvs.common.ui.Publisher();
            //Start publisher
            result = pub.doPublish(false, true, objRef, (wt.vc.config.ConfigSpec) null, (wt.vc.config.ConfigSpec) null, true, null, null,
                    com.ptc.wvs.common.ui.Publisher.EPM, pa.toString(), 0);
        }//if
    }//while
} catch (wt.util.WTException e)
    e.printStackTrace();
