Dec 12, 2024 7:13 AM UTC
Publishing - WT Document
Hi Guys,
Some WT Document is not published, how we can publish in Windchill with Bulk.
AJ
HelesicPetr
Dec 16, 2024 9:45 AM UTC
Hi @Amirtharaj_K
Each context has Utility and there is visualization scheduler as I've mentioned in the first replay.
PetrH
HelesicPetr
Dec 12, 2024 10:17 AM UTC
Hi @Amirtharaj_K
Check WVS Job Scheduler Administration on the Site
PetrH
Dec 12, 2024 5:52 PM UTC
@HelesicPetrThank you for your bulk approach. Can we publish counts by number? I have over 3 lakhs of data in my Windchill.
Aj
avillanueva
23-Emerald II
Dec 13, 2024 1:54 PM UTC
Not sure I follow "publish counts by number". What do you mean? For non-speakers, lakhs=hundred thousand. You can control this by context, you can also pause the queues and let the job generate to see how many would have started if you let it fly.
