Purge Selection Criteria Help
Using Pro/Intralink 9.1
I'm trying to set up a purge job of our Pro/Engineer CAD Documents and I'm struggling a little with the query criteria.
What I want to keep is the last 3 Iterations of every Revision. For example, for a VERY active CAD Document, the versions I want to KEEP in the system after the purge would be:
* -.6, -.7, -.8
* A.11, A.12, A.13
* B.2, B.3, B.4
* C.1
* D.1, D.2
I don't want to throw away any Revisions. I need to keep the latest (3) CAD Documents at Revisions -, A, B, etc. But I don't want to keep Version A.10, for example.
I THINK the following criteria will obtain the desired result:
* Object Type: Workgroup Manager CAD Document
* Iteration: All but last 3 iteration(s)
Will this provide the desired result?
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics | +1 440 326 5555 | F: +1 440 284 1090
* -.6, -.7, -.8
* A.11, A.12, A.13
* B.2, B.3, B.4
* C.1
* D.1, D.2
