Oct 13, 2010 8:17 PM UTC
purging iterations
after moving to version A.3 how do you remove iterations A.1 and A.2?? i would appreciate any help that can be given
Thanks in advance
Brian
Oct 16, 2010 3:19 AM UTC
You can use the OTB function "Purge" to achieve your goal.
The Purge tab located at site-->utilities-->Purge Manager.
You should establish the purge rules first,then you establish the job to execute purge task.If your purge task execute successfull,you will find the iterations have been purged.And if you want to purge the document/EPMDocument from the external vault ,you should also execute the "remove unreferenced files",then the entity will be remove from the filevault,and you can save much space.
I have used this function for many times,if you have any questions,let me know it please.
Oct 16, 2019 3:42 PM UTC
I need to purge some older iterations of a family table can you help guide me? I found the purge command and collector but can't where to specify the part number
Oct 16, 2019 4:21 PM UTC
Do NOT purge items from a family table! That is asking for trouble.
A family table is a single file. There are no separate files for instances to be purged.
