Mar 6, 2023 6:26 AM UTC
Quantity Number Mismatch between creo assembly and Windchill part structure.
I have creo assembly,
In which  A.prt file is present two times.
Then do we need to create two separate Wtpart and associate them with .prt files.
or else What i should do.
Thanks in advance
Vipul
joe_morton
Mar 6, 2023 10:10 PM UTC
Typically a CAD file is linked to a single WTPart using an "Owner" link. On check in of the CAD assembly, Windchill by default will "build" the associated WTPart structure.
If the CAD part is present 2 times, Windchill should show the WTPart with quantity = 2.
joe_morton
