Mar 19, 2015 6:37 AM UTC
Query latest revision of the part using Info engine
Hi Everyone,
If I query a part(using Info engine Query-Objects webject) on number field, then i get all the revisions of the object but I want to query only the latest version.
Could someone help me out on this.
Regards
Sudeep Pai
PrabhashAnswer
Mar 19, 2015 3:27 PM UTC
Hello Sudeep,
You can use below 'Search-Objects' webject for this purpose. Just replace partNumber attribute value in below task according to your data set.
<%@page language="java"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<!-- get wtproperties -->
<ie:webject name="Get-Properties" type="MGT">
<ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/>
<ie:param name="GROUP_OUT" data="properties"/>
</ie:webject>
String partNumber = "RAM";
<ie:webject name="Search-Objects" type="OBJ">
<ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])"/>
<ie:param name="authorization" data="$(@SERVER[]AUTHORIZATION[0])"/>
<ie:param name="type" data="wt.part.WTPart"/>
<ie:param name="WHERE" data="(number='<%=partNumber%>')"/ >
<ie:param name="attribute" data="number,name,version,lifeCycleState" delim=","/ >
<ie:param name="VERSION" data="LATEST"/>
<ie:param name="ITERATION" data="LATEST"/>
<ie:param name="group_out" data="objectsSearched"/>
</ie:webject>
Please, let me know if you need more information.
Prabhash1-VisitorAnswer
Hello Sudeep,
</ie:webject>
</ie:webject>
spai-21-VisitorAuthor
Mar 20, 2015 6:32 AM UTC
Thanks a lot!!!
