Jul 15, 2019 11:12 AM UTC
Query-object search results size has exceeded the limit but the result size is less then the limit
I have a Windchill query-object which is returning the exception size has exceeded the limit of 200000. I updated the limit to 400000 then I got the result which strangely counts less then 200000.
Then I tryed to add paging to the query but got this exception:
Exception message:
com.ptc.core.command.common.CommandException: (wt.pom.pomResource/22) wt.pds.PartialResultException: Search results size has exceeded the limit set by the System Administrator.
Nested exception is: (wt.pom.pomResource/22) wt.pds.PartialResultException: Search results size has exceeded the limit set by the System Administrator.
Could you please help?
Thanks in advance.
Jul 15, 2019 11:40 AM UTC
There are several query limit properties and we don't know which ones are used by an Info*Engine query.  You can log a call with PTC Tech Supt but I would start by searching the PTC knowledge base on the more unique key words in your error: "wt.pom.pomResource/22" and "wt.pds.PartialResultException".
https://www.ptc.com/en/support/article?n=CS301334
https://www.ptc.com/en/support/article?n=CS26116
https://www.ptc.com/en/support/article?n=CS54402
