Jan 18, 2016 9:04 PM UTC
Query Report WTparts - CAD parts / CAD Assemblies
Does anyone have a report that will check to make sure there are WTparts created for all CADParts or CADassy files and spit back a list if the answer is NO?  If there is a way to select the product, that would be fantastic.  I looked through the reports already uploaded here and didn't see exactly what I was looking for.
MarcoTosin
Jan 19, 2016 7:43 AM UTC
Jan 19, 2016 4:13 AM UTC
Hi Greg,
Have you tried to run a report on WTpart and EPMDoc using EPMBuildRule?
buildRule.IdA3A5=EPMDoc.branchIditerationInfo
and
buildrule.IdA3B5=WTPart.branchIditerationInfo.
For product:
WTPart.idA3ContainerReference=PDMLinkProduct.idA2A2
Not sure yes and no is possible through QML.You can try that with SQL.
Pardeep
Jan 19, 2016 7:40 AM UTC
Below SQL will list all CAD document which does not have WTPart you can modify SQL as per your requirement
select A1.* from ControlBranch A0,EPMDocumentMaster A1
  where  A1.idA2A2=A0.idA3B5 and A0.idA2A2 not in ( SELECT A2.branchIdA3A5
FROM EPMBuildRule A2)
Hope it helps
Shreyas
MarcoTosin
GregOlson16-PearlAuthor
Jan 19, 2016 11:57 AM UTC
Marco...that must be from the case I opened with PTC.  Very quick turn around these days!
MarcoTosin
Jan 19, 2016 12:40 PM UTC
Marco
