Nov 14, 2018 12:59 PM UTC
Question about Disaster recovery with Windchill and Oracle datbase on separate servers
Hello all,
If we have an Windchill application backup that occurs at 9 PM and an Oracle database backup that occurs at 8 PM, can we still restore Windchill 11 incase of complete server failure?
Thanks!
TomU
TomUAnswer
Nov 14, 2018 1:52 PM UTC
As long as the application can talk to the database, it should start just fine.  I suggest you try it.  Take your backups and try to start them in a disaster recovery scenario.  (Virtual machines make testing this very easy.)
TomU
Nov 14, 2018 1:35 PM UTC
Should be able to but you would probably need to delete everything in the file vault that was created after the database backup took place.  The database won't have any record of those newer files and will try to reuse those same files names (and fail.)
mkohn4-ParticipantAuthor
Nov 14, 2018 1:47 PM UTC
But the application will still come up? I am having a discussion with one of our developers and he thinks the application won't start and I think we would just tell the user to redo the part.
TomU
TomU23-Emerald IVAnswer
