Questions about "association types" continued
Thanks to all who helped me understand the Owner association type yesterday.
The questions for today are about the Contributing Image association type, one of the association types between CAD Doc and WT part. This is fromthe Windchill Help file for this association type:
"This association combines representation and attribute passing. Although a contributing image does not ’drive’ structure, it contributes to the product structure of a parent object. For example, a flexible component (cable) may occur, say, three times in an assembly but routed differently in each case. While Pro/ENGINEER requires separate model files for each routing, these models can be associated to a single part (one having an owner link and two having contributing image links). The resultant product structure would show three occurrences of a single part."
1. First, I need to understand the two words used. What is it "contributing"?
2. What "Image" are they talking about? Is this the ProductView image? I thought that was called a representation. Why is it called an image if it's not really an image file like .jpg or .bmp? Again, the words they use I already have definitions for, but they have a different meaning in mind.
3. What does it mean "it contributes to the product structure of a parent object." Since it's not driving, but contributing, is that like my wife in the passenger seat every time I drive? No seriously, I don't understand the sentence. I understand "parent" as in "Parent/Child" relationship in Pro/E, is this what they mean?
4. Whoever wrote that help paragraph does not understand flexible components in Pro/E. Maybe they didn't really mean the Pro/E term "Flexible", maybe they meant "easy to bend". In Pro/E, if a flexible component is used three times, is still only requires one model, that's the whole idea, so the example is worthless as an explanation of this association type.
5. In addition, I tried to associate three CAD Documents to a WT Part, just like the help states, with one having an owner association and two having contributing image associations, but Windchill errors and tells me that "Multiple Contributing Image Associations are not allowed with the same part." So either the help is wrong, or I'm more lost than I realize. I'm still waiting for PTC tech support to answer this last question.
I would really like a real world example of using this association type that actually works the way PTC intended it to.
