3-Newcomer
Jan 10, 2025 7:05 AM UTC
Questions About the Handling Method for CASE Article - CS323888
Version: Windchill 11.2
CASE SUP: Article - CS323888 - Installing CPS18 requires Multi-Language Pack CD in staging area but it's not found on PTC's download page for Windchill PDMLink 11.0 M030
Use Case:
Currently, I am using the CPS22 version bundle for the installation process.
My test computer has never had any WindChill installed.
The path is set to D:\WindchillInstall.
The folder paths are as follows:
  • D:\WindchillInstall
  • D:\WindchillInstall\MED-61006-CD-110_M030_M030-CPS22-Bundle
ownload URL: https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=WPD
I have tried downloading the following files and placing them in the specified path:
  • PTC Windchill Multi-Language Pack Version: 13-1-0-0
  • PTC Windchill Multi-Language Pack Version: 13-0-2-0
  • PTC Windchill 12.0 Multi-Language Pack Version: 12-0-2-20
  • PTC Windchill PDMLink 12.0 Version: 12-0-2-7
However, the installation process still cannot find the files.
Has anyone else experienced a similar issue?
Could it be due to a language translation problem, or is there something I am doing wrong?
Description:
Jan 13, 2025 12:55 PM UTC
PTC hasn't removed Windchill 11.0 from their software downloads yet.  It is the second one.
If the 11.0 Multi-Language Pack is not available to you from the PTC website, then you need to log a call with PTC to get access to it.
Also, remove all other Multi-Language packs from your software staging area in case the installer defaults to the latest available during installation.
Jan 10, 2025 11:37 AM UTC
The list of downloads you provided in the description are for 12.0, 13.0, and 13.1.  When installing 11.0, you need the 11.0 Multi-Language Pack that matches the version requested by the PSI Installer "M030-CPS18".
AbeLin3-NewcomerAuthor
3-Newcomer
Jan 13, 2025 12:25 AM UTC
HI Sir
Could you please tell me which option I should click to download?
I have tried downloading all versions of the Multi-Language Pack from the download page and putting them in my installation path, but the problem still occurs.
