Radio button Layout
- 0 replies
- 914 views
- Translate All
I am using radio buttons with few values.
By default Windchill11 allows only vertical layout. Means if there are many values, it will be a long list as well I need many attributes that need radio buttons. Result is the long-long page.
Kindly see the attached image that explains what I want. Even better would be grid as it can take-up more values.
Thank you for your replies..
- Ravi
