Dec 2, 2014 12:58 PM UTC
Refreshing / reloading MVC Table
Dear Guys,
Can you pls share your toughts in making a table created with MVC framework refresh without loosing its content or navigating to the default/home page.
Dec 2, 2014 2:40 PM UTC
So you have a MVC table that is a customization and you want to update it or navigate away from it, but not lose the previous data for the “session”?
Dec 2, 2014 5:30 PM UTC
Yes David . Basically the MVC table contains Roles & User Info. If i add a user to the customised table , i expect a internal refresh to happen within the mvc table without the page getting refreshed.
Dec 2, 2014 7:29 PM UTC
You can use <script language="javascript">
var ecnImg = document.getElementById('mvcTable');
var number = document.getElementById('partSearchNum').value;
var params = {
//reload the table builder
Dec 2, 2014 8:23 PM UTC
NOTE: This will reload the table from the server side, but is invoked from the client side. It cannot be used from the server side to refresh only the table content after the table is modified. PTC API encapsulates the ExtJS API.
