8-Gravel
Feb 6, 2024 5:18 PM UTC
Rehost Error " Invalid object name 'Repository'.
Hi everyone, I have a problem running the rehost process.
The log gives the following message:
[DBValidator] Connecting to jdbc:sqlserver://gama
[DBValidator] com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'Repository'.
[DBValidator] at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:262)
[DBValidator] at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1624)
[DBValidator] at com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:868)
[DBValidator] at com.microsoft.sqlserver.jdbc.SQLServerStatement$StmtExecCmd.doExecute(SQLServerStatement.java:768)
[DBValidator] at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7194)
[DBValidator] at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2979)
[DBValidator] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:248)
[DBValidator] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:223)
[DBValidator] at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeQuery(SQLServerStatement.java:693)
[DBValidator] at com.ptc.wc.rehost.validate.DBConnectionValidator.performTask(DBConnectionValidator.java:50)
[DBValidator] at com.ptc.wc.rehost.javatask.AbstractRehostTask.execute(AbstractRehostTask.java:73)
[DBValidator] at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:299)
[DBValidator] at jdk.internal.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
[DBValidator] at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[DBValidator] at java.base/java.lang.reflect.Method.invoke(Method.java:566)
[DBValidator] at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99)
[DBValidator] at org.apache.tools.ant.Task.perform(Task.java:350)
[DBValidator] at org.apache.tools.ant.Target.execute(Target.java:449)
[DBValidator] at org.apache.tools.ant.Target.performTasks(Target.java:470)
[DBValidator] at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401)
[DBValidator] at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:36)
[DBValidator] at org.apache.tools.ant.Project.executeTargets(Project.java:1264)
[DBValidator] at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:437)
[DBValidator] at java.base/java.util.Vector.forEach(Vector.java:1394)
[DBValidator] at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:67)
[DBValidator] at net.sf.antcontrib.logic.IfTask.execute(IfTask.java:197)
[DBValidator] at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[DBValidator] at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[DBValidator] at org.apache.tools.ant.TaskAdapter.execute(TaskAdapter.java:155)
[DBValidator] at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget.java:106)
[DBValidator] at net.sf.antcontrib.logic.ForEach.executeSequential(ForEach.java:178)
[DBValidator] at net.sf.antcontrib.logic.ForEach.execute(ForEach.java:254)
[DBValidator] at org.apache.tools.ant.Project.executeTarget(Project.java:1374)
[DBValidator] at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
[DBValidator] at org.apache.tools.ant.Main.runBuild(Main.java:818)
[DBValidator] at org.apache.tools.ant.Main.startAnt(Main.java:223)
[DBValidator] at org.apache.tools.ant.launch.Launcher.run(Launcher.java:284)
[DBValidator] at org.apache.tools.ant.launch.Launcher.main(Launcher.java:101)
!+! ERROR OCCURRED @ C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\modules\Database.xml:8: !!!
[ant] Exiting C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\modules\Database.xml.
!+! EXITING FROM Database[C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\modules\Database.xml]
!+! RETURNING TO Rehost[C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\rehost.xml]
!+! ERROR OCCURRED @ C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\rehost.xml:210: !!!
[antcall] Exiting C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\rehost.xml.
!+! EXITING FROM ANTCALL WITHIN Rehost[C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\rehost.xml]
!+! ERROR OCCURRED @ C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\rehost.xml:177: !!!
!+! FINISHED @ Tue Feb 06 08:11:11 PST 2024
!+! Log: C:\ptc\Windchill_12.1\Windchill\buildlogs\0042-rehost.log
BUILD FAILED
C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\rehost.xml:177: The following error occurred while executing this line:
C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\rehost.xml:210: The following error occurred while executing this line:
C:\ptc\Windchill_12.1\Windchill\utilities\wcRehost\conf\modules\Database.xml:8: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'Repository'.
I've already done the step in Article - CS268509 and the error still persists.
jbailey
18-Opal
Feb 7, 2024 1:35 PM UTC
Is the SA account enabled for login? In my limited Windchill / MS SQL experience I remember that the SA account had to be set for login during install, but after that it was not used.
8-Gravel
Feb 7, 2024 2:28 PM UTC
Yes, The user was configured to login at the time of installation.
Oct 15, 2024 3:19 AM UTC
I got the same error with rehost too
Oct 17, 2025 3:16 AM UTC
I know this is quite old but I stumbled across this becasue I had the exact same issue and managed to resolve it.
The 'Repository' it is referring to is a table in the wcadmin database. I am using SQL server with all the defaults so there is a wcadmin database with that table and hundreds of others. After much gnashing of teeth I worked out that my SQL server login (also wcadmin) that I have in my rehost file did not have the user mapping to the wcadmin database with the wcadmin default schema. (Note in SQL server you have a user under the database and a login at the server level, both under security in SSMS. The login can have users underneath it under the user mapping section of the login.)
I have this setup
SQL server instance: MSSQLSERVER01
Host: myHostName
Database: wcadmin
Default Schema: wcadmin
Database User: wcadmin
Server Login: wcadmin (and this requires user mapping to the wcadmin database for user wcadmin, default schema wcadmin)
The info in the rehost file is the server login info and it uses this to connect to the database and hence the table Repository.
I tried the GUI to set up the User Mapping to the database but this kept failing. So I ended up using this script using SSMS
USE wcadmin
EXEC sp_change_users_login 'Auto_Fix', 'wcadmin'
This fixed orphan users and then my rehost worked.
