Apr 28, 2015 12:46 PM UTC
Rehost Info*Engine Adapter Setting
I am a little confused with the rehosting guide on the adapter. On page 122 under target.adapter.name, it says "The adapter on the target system takes its name from name of the adapter on the source system. Specify the source system name in this rehosting property."
So if my adapter name is the following: com.<company_network>.<source_server>.Windchill, will my target.adapter.name.1=com.<company_network>.<source_server>.Windchill or do I put in the target server name? If I leave the source name, when/how does that change?
Their directions seem backwards to me with what everything else tells me to do in other sections for target.
Thank you,
Brian
TomU
TomUAnswer
Apr 28, 2015 2:09 PM UTC
Not sure why it's working, but I do have the source adapter names listed for the names, but the properties changed to match the target. However after rehost the adapters all have their names changed to match the target system.
TomU
TomU23-Emerald IVAnswer
TomU
Apr 30, 2015 1:48 AM UTC
Brian,
Did you observe the same behavior? It seems like the adapters get copied from one system to another with their previous name. I think InfoEngine might handle renaming them and then IEAdapter handles changing their properties. There does seem to be some weirdness between what is documented and how the IEAdapter task actually works. It says to only list things you want to change, but I'm having issues if I don't list everything. I'm still trying to figure out how to get the Active Directory adapter to copy over correctly. Did you get it to work?
Apr 30, 2015 11:06 AM UTC
Tom,
Yes I saw the same thing. It just gets confusing when they expect the target server name for everything else that is named target. It seems that should have been named source. Everything seemed to change correctly. However I still cannot login via our corporate LDAP.
TomU
May 12, 2015 4:55 PM UTC
Brian,
I have managed to get everything related to the corporate LDAP adapter to properly rehost except for the password. After repeating this process many times (virtual machines with snapshots are wonderful!), I was able to determine several things:
  1. ALL adapter properties must be included in the rehost.properties file. If you leave some out, the rehost tool will mangle them. Some properties get their values changed and others get truncated. By listing ALL the properties and values, everything stays intact - even if nothing is changing.
  2. The LDAP adapter's properties are stored in the configuration node of the Windchill Directory Server. Once you know where they are it's very easy to copy and paste them from production to test and also to copy these same lines to the rehost.properties file.
  3. The corporate LDAP connector's password is stored in the Windchill "mapcredentials.admin.adapters" property, not in Windchill DS. The rehost tool resets this password to the same one entered for the administrative and enterprise LDAP adapters. At this point I have not been able to figure out how to get the rehost tool to accept a different password for the corporate LDAP adapter. (I have a case open with PTC on this.) My current solution for now is to recreate the property from a Windchill shell after rehosting prior to startup. Below is the syntax I use for this.
xconfmanager -s "mapcredentials.admin.adapters=com.tm.Ldap^cn=Manager^password_goes_here"
xconfmanager --add "mapcredentials.admin.adapters=com.tm.EnterpriseLdap^cn=Manager^password_goes_here"
xconfmanager --add "mapcredentials.admin.adapters=com.tm.ActiveDirectory^cn=Windchill,ou=Users,dc=tm,dc=com^password_goes_here"
xconfmanager -p
